PIX vlan and DMZ
Oct 11, 2006 2 Replies
Hello,
Please bear with me, I'm helping with an office transition from one company to another. In the process the old company wiped the configuration of the PIX 506. I'm trying to get everything up and running again.
We have a Cisco 2950 switch with 2 vlans (10 and 20). Port 24 is the trunk port, set as 802.1Q trunking.
On the PIX, I can get vlan 1 to work fine. VLAN 2, I can ping the router, but can't get to the internet. VLAN2 from my understanding was setup to allow some videoconferencing equipment to work.
here's part of the configuration:
PIX Version 6.3(5) interface ethernet0 10full interface ethernet1 auto interface ethernet1 vlan20 logical nameif ethernet0 outside security0 nameif ethernet1 inside security100 nameif vlan20 DMZ security50
access-list 100 permit tcp any host xx.xx.xx.2 eq smtp access-list 100 permit tcp any interface outside eq www access-list 100 permit tcp any interface outside eq https access-list 100 permit tcp any interface outside eq 3389
ip address outside xx.xx.xx.2 255.255.255.248 ip address inside 172.30.40.254 255.255.255.0 ip address DMZ 172.30.70.254 255.255.255.0
global (outside) 10 interface
static (inside,outside) tcp interface www 172.30.40.2 www netmask
255.255.255.25
5 0 0 static (inside,outside) tcp interface 3389 172.30.40.2 3389 netmask
255.255.255.
255 0 0 access-group 100 in interface outside route outside 0.0.0.0 0.0.0.0 xx.xx.xx.1 1 route inside 172.30.40.0 255.255.255.255 172.30.40.254 1
I feel as though it's an access list/group issue, but I can't for the life of me get it figured out.
The first line of your ACL refers to host xx.xx.xx.2, and your ip address outside is given as xx.xx.xx.2 . If those are the same IP address, then your first line must be rewritten as
access-list 100 permit tcp any interface outside eq smtp
That route inside statement is redundant: it would be put in place automatically because of the 'ip address inside' (the range is the same as the inside address range, and the destination IP is the same as the PIX inside interface IP.)
The reason your VLAN2 cannot reach the outside is that you have not established any translation for it, at least not in the part you have shown. You haven't established any translation for most inside hosts either.
Try,
nat (inside) 10 172.30.40.0 255.255.255.0 nat (DMZ) 10 172.30.70.0 255.255.255.0
You wouldn't be able to ping the router if you didn't have some kind of translation already in place.
If you are trying to ping from inside or DMZ to outside hosts, I would recommend that you add
access-list 100 permit icmp any any echo-reply access-list 100 permit icmp any any unreachable access-list 100 permit icmp any any time-exceeded
These are needed because the PIX cannot reliably determine that any particular icmp message is a "response" to traffic that went outwards, so you have to configure the PIX as if the desirable icmp are "new" traffic inwards.
Ok,
Followed your suggestions and both vlans work as well as the video conferencing.
Thank you very much.
As far as this comment:
Do I need to establish translation for the individual hosts? Keep in mind I've never claimed to be a Cisco expert.
