Problem with DMZ
Apr 01, 2005 1 Replies
Hi. I have a problem with 'configuring/making' a DMZ. My network looks like this: Internet PIX 506 Switch 2600 LAN. And if I wan't to plug a mail server to the switch (the pix interfaces and the
2600 outside interface have routeable "external" addresses) should I configure it with a non-routeable IP address and make a static mapping on the PIX, or give him a routeable IP from the same network that PIX and
2600 have and permit traffic on the PIX access list? Or should I do it in some other way?
Well i would go with a routable address, it seem to be simple that way.
Let's assume that your "Switch" subnet is a.b.c.0 255.255.255.0
This means that your PIX inside have an address from this subnet , right.
So if you want your mail server to have an non-routeable address, for it to reach the PIX it would need to route through the 2600 wich would need a secondary address of that non-routeable subnet. Remember, that the pix cannot have a secondary address on an interface. With a routable address you will not need that stuff.
So on your PIX just do a
*static (inside,outside) a.b.c.0 a.b.c.0 netmask 255.255.255.0 0 0 * if not already done, to make your internal subnet visible on the outside and then filter the access needed through the outside access-group
