Hi everyone,
I was wondering if anyone has configured a pix in the following manner.
I have a single static routable ip with another /29 routed to it. I have this ip setup as the ip address on the outside interface.
The inside is 192.168.0.* and the dmz is 10.10.10.*.
I have the 192.168.0.* routing over my single static ip (nat). (this works). I also have the dmz functioning as a set of static routes from my /29 to the 10.10.10.* range (that works).
Here's where the problem is: i am unable to ping/communicate with the /
29 from the inside interface, even though both the dmz and the inside interface are setup for nat.
I'm assuming there is some sort of command to allow for the traffic to flow from inside to public (outside) to dmz.
Has anyone been able to do this?
Thanks, Jack
