PIX 515E DMZ with Public IP and Inside with Private IP
Feb 27, 2007 2 Replies
Hi, I have T1 with a class C that is subnetted into two for Outside and DMZ network with Inside using private IP address. My question is how do I configure the DMZ to use the public address without NATing to the Outside IP address. All the config sample I found uses Outside public IP address NATed to the DMZ private network? i.e., DMZ with web server using IP address from Outside network.
I am looking for sample configuration that uses public IP on the Outside, public IP on DMZ and Private IP on the Inside.
TIA, BK
network.http://www.cisco.com/warp/public/110/mailserver.html>
Actually you can use both for webservers inside, you can statically nat the webserver public ip to a private and both local and public users will have access to the webserver.
Or you can not to nat using command nat 0.
GoodLuck Andy.
I tried the NAT 0, but it didn't work. I am justing to use NAT on dmz to make it easier.
