PIX 501 reset
Dec 15, 2006 3 Replies
Jump to replies (3)
PIX 501 reset open original image
Have a pix501 pulled from a network. When I connect via console all I have for options is this: enable Turn on privileged commands help Help list login Log in as a particular user logout Exit from current user profile, and to unprivileged mode pager Control page length for pagination quit Quit from the current mode, end configuration or logout matt>
Is there a default login that I could try or how would I reset it.I'm very new to this so any help would be appreciated.
The default password is cisco
You may wish to investigate PIX Password Recovery:
Sincerely,
Brad Reese
Thank you. Now this newb needs to figure out how to see whats been setup up on it previously and configure it to specs needed.
