Hardware-address AND client-identifier
Dec 15, 2006 0 Replies
Hello,
i'am using a dhcp server in a cisco 2610. That works good. Now a have some static dhcp addresses as pools manualy defined. That works, too.
For Microsoft windows clients i've defined the pool with the client-itentifier. For all other clients, with the hardware-address.
But with some PXE devices a have a problem. That are windows clients and use PXE. When i define the client-identifier, windows get the correct ip address, but the PXE use an ip address from the dynamic pool. When i define the hardware-address, windows use a dynamic ip address.
What can i do? I want an static dhcp entry for the microsoft client (XPe) and for PXE on the same maschine and nic (one hardware-address), that use the same ip address!
Martin
