asa 5510 tunnels L2L
May 19, 2009 0 Replies
Hi
There is some technical reason that we should disconnect L2L tunnels ?
default options in Cisco is: vpn-idle-timeout 30
I sometimes use none, which mean: IPsec VPN: Disable timeout and allow an unlimited idle period;
i notice that stats: The number of connections which are currently active still grow. Its strange for me because tcp session should be reset after specific time for tcp session
what kind os session it is ?
regards Wald
