Asterisk Broadvoice outbounds calls go to voicemail on BV contral panel
May 16, 2006 0 Replies
Ok i had a loop where i would dial a number and it would ring my extension
i made a change in
;For outgoing calls this setup would dial my extension back.. loop loop exten => _1NXXNXXXXXX,1,dial(SIP/1002,60) exten => _1NXXNXXXXXX,2,congestion() exten => _1NXXNXXXXXX,102,busy()
to this
;For outgoing calls this now sends me to my voicemail exten => _1NXXNXXXXXX,1,dial(SIP/ snipped-for-privacy@sip.broadvoice.com,60) exten => _1NXXNXXXXXX,2,congestion() exten => _1NXXNXXXXXX,102,busy() and if i disable voicemail in broadvoice control panel i get a 503 service not avail... i feel like breaking something
Heres my current config.. but i cant dial out.. i hope its vb and not me
sip.conf [general] context=from-broadvoice bindport=5060 bindaddr=0.0.0.0 srvlookup=yes pedantic=no disallow=all allow=ulaw allow=ilbc allow=alaw allow=gsm port=5060 register => 3109439035: snipped-for-privacy@sip.broadvoice.com [sip.broadvoice.com] type=friend host=sip.broadvoice.com user=phone username=3109439035 secret=bvPassword fromdomain=sip.broadvoice.com fromuser=3109439035 insecure=very context=from-broadvoice dtmfmode=inband canreinvite=no qualify=yes
[1002] username=1002 ;extension for xlite type=friend secret=1002 qualify=yes port=5060 nat=never host=dynamic dtmfmode=auto disallow=all context=from-broadvoice canreinvite=no allow=g729 allow=g723.1 allow=gsm allow=ulaw allow=alaw
extensions.conf [general] static=yes writeprotect=no autofallthrough=yes clearglobalvars=no priorityjumping=no
[from-broadvoice] ;For incoming calls ;This extension line will ring SIP ;extension 1002 for 60 seconds then hang up. Modify as necessary to fit your dialplan exten => 3109439035,1,Dial(SIP/1002,60,tr) exten => 3109439035,2,hangup
Incoming works great! but a bit choppy, so if any one can help me get calls going out thanks in advanced.
-- Joel Bueno
Contact Me: joel.bueno at gmail.com joel at centurymedia.com joelbueno13 AOL Messenger supersaijin_therock at hotmail MSN Messenger supersaijin_therock Skype
