Need recommendation on firewall and vpn replacement
May 01, 2009 4 Replies
Jump to replies (4)
Need recommendation on firewall and vpn replacement open original image
We've got a pair of PIX 525s in active/standby mode, plus a pair of VPN 3005 concentrators (one active, one redundant using vrrp) for IPSec VPN connections (both LAN-to-LAN and Remote Access, 3DES). I'm trying to generate a proposal to replace all 4 devices with more current equipment.
From Cisco's website, it looks like the ASA 5520 is the recommended replacement for the PIX 525 and there's an SSL/IPSec VPN Edition recommended for replacing the 3005s. The SSL/IPSec VPN edition seems to be a fair bit more expensive than the other version... Can just the a pair of ASA 5520s handle the job of what we're using now, or do we really need the more expensive version?
Also, I've seen mention of a Technology Migration Plan from Cisco. Would this apply here, or is it even still evailable?
Thanks!
--Steve
Cisco pretty much is leaving basic IPsec VPN client behind. It does not support 64-bit WinXP or 64-bit Vista, and most likely never will. Without the SSL VPN edition of the ASA, you can't support these OSs. Their new VPN client, the AnyConnect VPN requires SSL VPN support on the ASA, and does support 64-bit windows OSes, and is what Cisco will be moving forward on.
So, depends on what you want to support in the future really.
Dunno.
So, if we weren't concerned about supporting 64-bit OSes, the cheaper one would probably work, otherwise we'd need the more expensive one, correct?
Thanks!
pfisterfarm schrieb:
There is a client from NCP
that supports IPSEC VPN on 64bit OS. So you could use that one. I think the SSL edition comes bundled with SSL-VPN licenses so that it would be cheaper to buy it with if you plan on using SSL-VPN. You can however upgrade the license later if you wish to.
Jens
You are right! IPSec VPN is free for base ASA
). A pair of base (cheaper) ASA 5520 will do both jobs of your old VPN
3005 and PIX 525.
Cheers!
