Help on Cisco ASA 5510 VPN IPsec
Jan 04, 2009 6 Replies
Jump to replies (6)
Help on Cisco ASA 5510 VPN IPsec open original image
Hi
i have a small problems with my new asa 5510:
I have configured a VPN IPSEC Service and no problems at the connection but after, when i want ping the lan i don't have a answer.
On one of my server, i see the packet with tcpdump, i see the reply of the server but on the ASA i have a message of the firewall ...
I have used the Wizard included into the 6.0 version.
Thanks for your help Mag
You need to post a santized config for us to be able to help you.
Brian V a écrit :
i add this:
sh access-list
access-list cached ACL log flows: total 0, denied 0 (deny-flow-max 4096) alert-interval 300 access-list lan_nat0_outbound; 1 elements access-list lan_nat0_outbound line 1 extended permit ip any IPSec
255.255.255.0 (hitcnt=0) 0xf555dd22 access-list All; 1 elements access-list All line 1 extended permit ip any IPSec 255.255.255.0 (hitcnt=0) 0x71dc000e
Are you trying to do a L2L ipsec or a remote access? You currently have a remote access vpn setup according to your config
tunnel-group ipsecvpn type remote-access tunnel-group ipsecvpn general-attributes address-pool IpSec default-group-policy ipsecvpn tunnel-group ipsecvpn ipsec-attributes pre-shared-key *
Before I tell you anything I just want to be sure.
here is the link from Cisco on how to do it via command line. I am personally not a fan of the gui for anything other than watching logs and cpu load.
Hi
Thanks for your answer, it's Remote Access IPSEC with the Cisco IPSEC Client.
i read your link mag
Mag a écrit :
Snifff anyone can help me ?
Mag
Mag a écrit :
arg ... no answer !!! very thanks for your help :=<
