Depends on what you mean by "small". The PIX 501 cannot handle VLANs at all, the PIX 506/506E can handle only 2 VLANs, and the 515/515E and 525 cannot handle more than a dozen VLANs in PIX 6.x (but can handle noticably more VLANs if you use PIX 7.0 for them.) The 5510 is pretty…
I have a small hosting center where each customer have their own VLAN on a swich. On this VLAN all their servers are placed. I need a firewall that can terminate the customers VPN connections and send the traffic into their own VLAN.
Can a small PIX do the job, or do I need a ASA 5510 securrity plus?
Regards /C
Why ? , you have W2K3- Servers, which can do the job better, than everyfirewall...
W
Walter Roberson
The 5510 is pretty small too. Perhaps you should give us some numbers -- number of VLANs you need, throughput you need, number of physical interfaces, total number of simultaneous VPN connections, nature of those connections (LAN to LAN or PC to LAN), encryption standards you require, VPN types required (IPSec, PPTP, L2TP). Also, is it acceptable for the VPN termination address at your end to be the same for all the customers, with the destination determined by the group name and password they log in with (PC to LAN) or by their source address (LAN to LAN) ? If you need distinct VPN termination addresses for each client, then it could be a bit of a challenge, that might be solvable if you have a WAN router that is able to route into different VLANs.
C
COZ
Hi Walter,
Thank you for your reply. It is just a testing firewall and I only need 10 VLAN's and 10 VPN's. Later I need a asa 5540.
But I have to make this firewall work with this funktionality. Are thire guides on the net about this setup?
All the VPN's has to be terminated into a VLAN. All the VLAN are connected to a switch with ONE cable... Is this posible?
/C
C
Cen
If they have servers inside (linux, ISA, Win2k, etc.), you can already use them as VPN terminators. Just another option for consideration.
Cen
J
jdsal
ASA-5510 does not support VLANs nor security contexts. At ASA-5520 and above both VLANs and contexts are supported.
ASA models comparison:
C
COZ
The ASA 5510 Security Plus supports 10 VLANs or am I missing something?
/C
Report Content
ASAP.
