More than two Ethernet interfaces on a 28xx router?
Oct 05, 2006 2 Replies
RC
I used to run a 2611 with a NM-4E and WIC-1DSU-t1, worked great and it was handling my firewall, VPN (L2TP/MPPE), 5 internal networks and the DMZ. You didn't say it was an XM so I'll assume it's not, you might want to check if the Fast Ethernet cards are supported on the…
More than two Ethernet interfaces on a 28xx router? open original image
I am currently using a 2611 where one FE is connected to my local LAN and the other is configured as dot1q trunk with approx 15 subinterfaces. This works like a charm, the traffic towards each remote site is mostly M&C, i.e. not bandwidth intensive. No routing between remote networks, the only traffic is between my local LAN and the respective remote networks.
Now I need to perform the same trick towards another set of remote networks. I need another ethernet interface on my router, running dot1q and with somewhere between 15 and 30 subinterfaces. I'd like to purchase a new Cisco router for this task, but I don't know how far up the ladder I need to climb to get a router with more than two Ethernet interfaces. From this page
doesn't look like the 28xx series support LAN network modules at all, as opposed to the 38xx series
). Unfortunately, I don't have an NM-1/2FE available for testing in my 2611. I know from earlier that it didn't recognize an older Ethernet WIC that I installed into one of the WIC slots.
Related to this: Is it possible to use a 3550 like this (router-on-a-stick)? On my 2611, I create as many sub-interfaces as I have VLANs to route, and on each subinterface I configure the following:
int fa0/1.501 encap dot1q 501 ip address
> it doesn't look like the 28xx series support LAN network modules at all,
