loopback network ignore
Jan 05, 2006 3 Replies
loopback network ignore open original image
Hi all, I need a solution to get rid of "loopback network ignore" I have on a T1 controller. Nothing worked: no loopback network ignore, lopp default, bouncing the controller, even reloading the box. Is a AS5350.
controller T1 2/0:1 framing esf loopback network ignore pri-group timeslots 1-24
any suggestion? thanks, robert
Did you try "no loopback"?
Regards, Steve
