cisco 2821 frame relay with wic
Jun 05, 2007 1 Replies
cisco 2821 frame relay with wic open original image
Hello, We have a Cisco 2821 router with vwic2-2mft t1 e1 card on it. We would like to configure frame relay but when we use interface command we cannot see serial port.
What should we use to be able to configure frame relay this card?
interface async?
thanks
You need to config the card first for what type of circuit you have, and then create a channel-group in the T1 controller section.
card type t1 0 0 ! controller t1 0/0 framing esf linecode b8zs channel-group 1 timeslots 1-24
Now, you'll end up with a Serial interface to configure.
