iChat and a NAT'ed c837
Mar 28, 2006 3 Replies
Jump to replies (3)
My brain has gone blank this evening. How can I get iChat to work through my NAT'ed 837. I'm running 12.2. I have got my mac on a static ip. This shows the ports that I need to open up
TIA
try
! iCHAT static NAT translations for port 5060, 5190, 5297, 5298, 5678,
16384-16403
! since 837 is probably setup to dpo port address translation ! for this to work only one inside host can use iCHAT
ip nat inside source static tcp 4896 interface 5060 ip nat inside source static tcp 4896 interface 5190 ip nat inside source static tcp 4896 interface 5297 ip nat inside source static tcp 4896 interface 5298 ip nat inside source static tcp 4896 interface 5678 ip nat inside source static tcp 4896 interface 16384 ip nat inside source static tcp 4896 interface 16385 ... ip nat inside source static tcp 4896 interface 16402 ip nat inside source static tcp 4896 interface 16403
Merv, Thanks for the reply. I'll certainly put those rules in. Is there any way in putting in a range statement for the ports 16384-16403 OR do I have to put in 1 line per port? Thanks
