How to tell if PDM is already installed on a PIX?
Dec 05, 2005 3 Replies
Walter Roberson
:I have a Cisco 515 running in failover and would like to know how to :find out if it already has PDM already installed. I can see several :pdm commands when I do a show command but the standard 'x.x.x.x :255.255.255.255 inside' and 'http server enable' information I…
I have a Cisco 515 running in failover and would like to know how to find out if it already has PDM already installed. I can see several pdm commands when I do a show command but the standard 'x.x.x.x
255.255.255.255 inside' and 'http server enable' information I configured doesn't get me anywhere when I try and connect via browser.
In article , wrote: :I have a Cisco 515 running in failover and would like to know how to :find out if it already has PDM already installed. I can see several :pdm commands when I do a show command but the standard 'x.x.x.x :255.255.255.255 inside' and 'http server enable' information I :configured doesn't get me anywhere when I try and connect via browser.
For PIX 6.x,
show flashfs
Then "file 3" is the pdm image. If the length is 0 then you do not have pdm installed.
Make sure you connect using https (with the "s" at the end).
snipped-for-privacy@gmail.com schrieb:
"show version" should tell you if PDM is installed on your firewall appliance:
---------- pixfirewall# show version
Cisco PIX Firewall Version 6.3(5) Cisco PIX Device Manager Version 3.0(4) [...]
