PIX 501 - where is error
Oct 09, 2005 4 Replies
Jump to replies (4)
i have PIX 501 - i am trying to connect via VPN client 4.6 Could you help me and tell me where is error
Building configuration... : Saved : PIX Version 6.3(4) interface ethernet0 auto interface ethernet1 100full nameif ethernet0 outside security0 nameif ethernet1 inside security100 hostname F-02 domain-name mmm.com fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names object-group service tcp_13 tcp description tcp ports for server on address 100.100.100.13 port-object eq 8080 access-list outside_access_in permit icmp any any log access-list outside_access_in permit tcp any host 100.100.100.13 object-group tcp_13 access-list 101 permit ip 192.168.1.0 255.255.255.0 0 pager lines 24 logging trap informational icmp permit any outside icmp permit any echo-reply outside icmp permit any router-solicitation outside icmp permit any inside mtu outside 1500 mtu inside 1500 ip address outside 100.100.100.11 255.255.255.248 ip address inside 192.168.1.1 255.255.255.0 ip audit info action alarm ip audit attack action alarm pdm location 100.100.100.14 255.255.255.255 outside pdm location 100.100.100.11 255.255.255.255 outside pdm location 192.168.1.28 255.255.255.255 inside pdm location 100.100.100.13 255.255.255.255 outside pdm location 192.168.1.30 255.255.255.255 inside pdm location 100.100.100.12 255.255.255.255 outside pdm location 82.0.214.175 255.255.255.255 outside pdm logging critical 100 pdm history enable arp timeout 14400 global (outside) 10 interface nat (inside) 0 access-list 101 nat (inside) 10 0.0.0.0 0.0.0.0 0 0 static (inside,outside) 100.100.100.13 192.168.1.28 netmask 255.255.255.255
0 0 access-group outside_access_in in interface outside route outside 0.0.0.0 0.0.0.0 100.100.100.9 1 timeout xlate 0:05:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server LOCAL protocol local aaa authentication ssh console LOCAL http server enable http 192.168.1.0 255.255.255.0 inside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable sysopt connection permit-ipsec no sysopt route dnat sysopt connection permit-ipsec crypto map inside_map 65535 ipsec-isakmp dynamic inside_dyn_map crypto map inside_map interface inside crypto ipsec transform-set myset esp-des esp-md5-hmac crypto ipsec transform-set myset esp-des esp-md5-hmac crypto dynamic-map dynmap 10 set transform-set myset crypto map mymap 10 ipsec-isakmp dynamic dynmap crypto map mymap client authentication partnerauth crypto map mymap interface outside isakmp enable outside isakmp identity address isakmp policy 10 authentication pre-share isakmp policy 10 encryption des isakmp policy 10 hash md5 isakmp policy 10 group 2 isakmp policy 10 lifetime 86400 vpngroup vpn3000 address-pool ippool vpngroup vpn3000 dns-server 192.168.1.2 vpngroup vpn3000 wins-server 192.168.1.2 vpngroup vpn3000 default-domain mmm.com vpngroup vpn3000 idle-time 1800 vpngroup vpn3000 password ****** telnet timeout 5 vpdn enable outside terminal width 80
where is ippool configured ?
ip local pool ippool x.x.x.x-y.y.y.y
ip local pool ippool 192.168.1.1-192.168.1.254
OK
i can connect - but i ca not connect - i can not to connect to any server and workstation I am using VPN client V 4.6.00.00045
i fixed some errors
PIX Version 6.3(4) interface ethernet0 auto interface ethernet1 100full nameif ethernet0 outside security0 nameif ethernet1 inside security100 hostname f-02 domain-name mmm.com fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names object-group service tcp_13 tcp description tcp ports for server on address 100.100.100.13 port-object eq 8080 access-list outside_access_in permit icmp any any log access-list outside_access_in permit tcp any host 100.100.100.13 object-group tcp_13 access-list 101 permit ip 192.168.1.0 255.255.255.0 any pager lines 24 logging trap informational icmp permit any outside icmp permit any echo-reply outside icmp permit any router-solicitation outside icmp permit any inside mtu outside 1500 mtu inside 1500 ip address outside 100.100.100.11 255.255.255.248 ip address inside 192.168.1.1 255.255.255.0 ip audit info action alarm ip audit attack action alarm ip local pool ippool 192.168.1.10-192.168.1.254 pdm location 100.100.100.14 255.255.255.255 outside pdm location 100.100.100.11 255.255.255.255 outside pdm location 192.168.1.28 255.255.255.255 inside pdm location 100.100.100.13 255.255.255.255 outside pdm location 192.168.1.30 255.255.255.255 inside pdm location 100.100.100.12 255.255.255.255 outside pdm location 82.0.214.175 255.255.255.255 outside pdm logging critical 100 pdm history enable arp timeout 14400 global (outside) 10 interface nat (inside) 0 access-list 101 nat (inside) 10 0.0.0.0 0.0.0.0 0 0 static (inside,outside) 100.100.100.13 192.168.1.28 netmask 255.255.255.255
0 0 access-group outside_access_in in interface outside route outside 0.0.0.0 0.0.0.0 100.100.100.9 1 timeout xlate 0:05:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server LOCAL protocol local aaa authentication ssh console LOCAL http server enable http 82.0.214.175 255.255.255.255 outside http 192.168.1.0 255.255.255.0 inside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable sysopt connection permit-ipsec crypto ipsec transform-set myset esp-des esp-md5-hmac crypto dynamic-map dynmap 10 set transform-set myset crypto map inside_map 65535 ipsec-isakmp dynamic inside_dyn_map crypto map inside_map interface inside crypto map mymap 10 ipsec-isakmp dynamic dynmap crypto map mymap interface outside isakmp enable outside isakmp identity address isakmp policy 10 authentication pre-share isakmp policy 10 encryption des isakmp policy 10 hash md5 isakmp policy 10 group 2 isakmp policy 10 lifetime 86400 vpngroup vpn3000 address-pool ippool vpngroup vpn3000 dns-server 192.168.1.2 vpngroup vpn3000 wins-server 192.168.1.2 vpngroup vpn3000 default-domain mmm.com vpngroup vpn3000 idle-time 1800 vpngroup vpn3000 password ******** telnet timeout 5 ssh 0.0.0.0 0.0.0.0 outside ssh 192.168.1.0 255.255.255.0 inside ssh timeout 5 console timeout 0 vpdn enable outside dhcpd address 192.168.1.30-192.168.1.120 inside dhcpd dns 83.146.21.5 83.146.21.6 dhcpd lease 3600 dhcpd ping_timeout 750 dhcpd domain thoughtwebfinancial.com dhcpd auto_config outside dhcpd enable inside
OK I solved a problem
with help If some one wants proper config reply post - i will post config
