PIX radius outbound authentication question
Nov 19, 2006 3 Replies
Jump to replies (3)
We have an antivirus hardware device needs to be installed on our LAN and it needs to bypass the PIX radius logon to access external website and get updated periodically. How can I set its IP address
192.168.150.50 in PIX so it can bypass the radius logon prompt? Attached is the config file. Thanks in advance.
-jesk
--------------------------------------------------------- PIX Version 6.0(1)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 pix/intf2 security10
nameif ethernet3 pix/intf3 security15
nameif ethernet4 pix/intf4 security20
nameif ethernet5 pix/intf5 security25
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list 101 permit ip 192.168.150.0 255.255.255.0 192.168.11.0
255.255.255.0
access-list 110 deny tcp host 192.168.150.10 any eq smtp
access-list 110 permit ip host 192.168.150.10 any
access-list 110 deny udp host 192.168.150.11 any eq domain
access-list 110 permit ip host 192.168.150.11 any
access-list 110 deny udp host 192.168.150.12 any eq domain
access-list 110 permit ip host 192.168.150.12 any
access-list 110 permit ip host 192.168.150.13 any
access-list 111 permit tcp any any eq www
access-list 111 permit tcp any any eq 443
pager lines 24
logging on
logging timestamp
logging monitor informational
logging buffered informational
interface ethernet0 auto
interface ethernet1 100full
interface ethernet2 auto
interface ethernet3 auto
interface ethernet4 auto
interface ethernet5 auto
mtu outside 1500
mtu inside 1500
mtu pix/intf2 1500
mtu pix/intf3 1500
mtu pix/intf4 1500
mtu pix/intf5 1500
ip address outside ----
ip address inside 192.168.150.1 255.255.255.0
ip address pix/intf2 127.0.0.1 255.255.255.255
ip address pix/intf3 127.0.0.1 255.255.255.255
ip address pix/intf4 127.0.0.1 255.255.255.255
ip address pix/intf5 127.0.0.1 255.255.255.255
ip audit info action alarm
ip audit attack action alarm
ip local pool vpnpool 192.168.11.1-192.168.11.254
no failover
failover timeout 0:00:00
failover poll 15
failover ip address outside 0.0.0.0
failover ip address inside 0.0.0.0
failover ip address pix/intf2 0.0.0.0
failover ip address pix/intf3 0.0.0.0
failover ip address pix/intf4 0.0.0.0
failover ip address pix/intf5 0.0.0.0
pdm location 192.168.150.11 255.255.255.255 inside
pdm location 192.168.150.27 255.255.255.255 inside
pdm location 192.168.150.10 255.255.255.255 inside
pdm location 192.168.150.200 255.255.255.255 inside
pdm logging alerts 100
pdm history enable
arp timeout 14400
global (outside) ----
nat (inside) 0 access-list 101
nat (inside) 1 192.168.150.11 255.255.255.255 0 0
nat (inside) 1 192.168.150.12 255.255.255.255 0 0
nat (inside) 1 192.168.150.13 255.255.255.255 0 0
nat (inside) 1 192.168.150.14 255.255.255.255 0 0
conduit permit icmp any any
route outside 0.0.0.0 0.0.0.0 ----
timeout xlate 12:00:01
timeout conn 12:00:00 half-closed 0:10:00 udp 0:05:00 rpc 0:10:00 h323
0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 12:00:00 absolute uauth 4:00:00 inactivity
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server AuthOutbound protocol radius
aaa-server AuthOutbound (inside) host 192.168.150.12 myauth timeout 3
aaa-server AuthOutbound (inside) host 192.168.150.11 myauth timeout 3
aaa authentication match 110 inside AuthOutbound
http server enable
http 192.168.150.200 255.255.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
virtual http 192.168.100.1
floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
service resetinbound
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set myset
crypto map mymap 10 ipsec-isakmp dynamic dynmap
crypto map mymap interface outside
isakmp enable outside
isakmp identity address
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption des
isakmp policy 20 hash md5
isakmp policy 20 group 1
isakmp policy 20 lifetime 86400
vpngroup lwvpn address-pool vpnpool
vpngroup lwvpn dns-server 192.168.150.12
vpngroup lwvpn wins-server 192.168.150.12
vpngroup lwvpn default-domain mydomain
vpngroup lwvpn split-tunnel 101
vpngroup lwvpn idle-time 1800
If I'm reading this right you should simply need to add .50 to ACL110
conf t access-list 110 permit ip host 192.168.150.50 any wr mem
That didn't work. It says: Please type your user name and password. Site: 192.168.100.1 Realm HTTP Authentication (ID38018) User Name Password
- OK / Cancel buttons
Question: how to config so .50 can connect to Internet without going through this dialog box?
Brian V wrote:
Would "aaa mac-exempt" command work in this case? I saw it in the PIX configuration documentation but never try that before. -jesk
jesk wrote:
