pix 6.3 pdm autoadded rules
Feb 07, 2007 1 Replies
installed pdm for the customer, added 12.12.12.12 255.255.255.255 outside (for me to test) and when you first connect, it says something about "having to add certain commands, for pdm to work properly)
then you click ok, and afterwards i find this in the config: a bunch of networks I don't even have behind the pix: (yeah, some are remote addresses, others are mentioned in access-lists)
pdm location 172.25.0.0 255.255.0.0 inside pdm location 192.168.1.0 255.255.255.0 inside pdm location 192.168.9.0 255.255.255.0 inside pdm location 10.10.11.0 255.255.255.0 outside
pdm location 172.16.72.0 255.255.252.0 outside pdm location 172.25.0.0 255.255.0.0 outside pdm location 192.168.1.0 255.255.255.0 outside pdm location 192.168.2.0 255.255.255.0 outside pdm location 192.168.9.0 255.255.255.0 outside pdm location 192.168.101.0 255.255.255.0 outside pdm location 192.168.102.0 255.255.255.0 outside
and adds my complete class c netz EXTERNAL pdm location 12.12.12.12 255.255.255.255 outside pdm location 12.12.12.0 255.255.255.0 outside
"pdm location" is the server where I can tftp the bin file from, as far as I remember, what's up?
cheers. M
pdm location commands,
Assists PDM with network topology discovery by associating an external network object with an interface. Note: The pdm location command does not control which host can launch PDM. See [no] http ip_address [netmask] [if_name] for this function
