Cisco 836 and Dial backup
Dec 05, 2005 0 Replies
i try to configure our 836 router. The A-DSL connection works without problem but with my configuration the ISDN Backup does not work. i tried to trigger the backup with shuting down the dialer1 oder atm0 interface but the dialer0 did not dial. Also removing the cable from the dsl does not help.
Maby someone has a clue?
version 12.3 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname 836router ! boot-start-marker boot-end-marker ! logging console informational enable secret 5 xxx ! username user privilege 15 password 0 xxxx aaa new-model ! ! aaa authentication login default local aaa authorization exec default local aaa session-id common ip subnet-zero ! ! ip dhcp excluded-address 10.0.0.1 10.0.0.59 ip dhcp excluded-address 10.0.0.91 10.0.0.255 ! ip dhcp pool lan network 10.0.0.0 255.255.255.0 default-router 10.0.0.3 dns-server 10.0.0.1 domain-name lan.de ! ! no ip domain lookup ip domain name lan.de ip ips po max-events 100 no ftp-server write-enable isdn switch-type basic-net3 ! ! ! ! crypto isakmp policy 10 encr 3des hash md5 authentication pre-share group 2 ! ! ! ! ! crypto ipsec client ezvpn RemoteLan connect manual group remotelan key xxx mode network-extension peer xxx.xxx.xxx.xxx ! ! !
interface Ethernet0 ip address 10.0.0.3 255.255.255.0 ip nat inside ip virtual-reassembly no ip route-cache ip tcp adjust-mss 1452 no cdp enable crypto ipsec client ezvpn RemoteLan inside ! interface BRI0 no ip address encapsulation ppp no ip route-cache dialer pool-member 2 isdn switch-type basic-net3 no cdp enable ! interface ATM0 no ip address no ip route-cache atm vc-per-vp 64 no atm ilmi-keepalive dsl operating-mode annexb-ur2 pvc 1/32 pppoe-client dial-pool-number 1 ! ! interface Dialer0 description DIALER PROFILE: INTERNET BACKUP ip address negotiated ip nat outside ip virtual-reassembly encapsulation ppp dialer pool 2 dialer idle-timeout 119 dialer string 012345 dialer-group 2 no cdp enable ppp authentication pap chap callin ppp chap hostname snipped-for-privacy@online.de ppp chap password 0 xxx ppp pap sent-username snipped-for-privacy@online.de password 0 xxx ppp ipcp dns request ! interface Dialer1 ip address negotiated ip mtu 1492 ip nat outside ip virtual-reassembly encapsulation ppp ip tcp adjust-mss 1452 dialer pool 1 dialer-group 1 no cdp enable ppp authentication pap chap callin ppp chap hostname xxx ppp chap password 0 xxx ppp pap sent-username xxx password 0 xxx ppp ipcp dns request crypto ipsec client ezvpn RemoteLan ! ip classless ip route 0.0.0.0 0.0.0.0 Dialer1 ip route 0.0.0.0 0.0.0.0 Dialer0 150 ! ip http server ip http secure-server ! ip nat inside source list 102 interface Dialer1 overload ip nat inside source list 103 interface Dialer2 overload ! access-list 23 permit 10.0.0.0 0.0.0.255 access-list 102 permit ip 10.0.0.0 0.0.0.255 any access-list 103 permit ip 10.0.0.0 0.0.0.255 any dialer-list 1 protocol ip permit dialer-list 2 protocol ip permit no cdp run ! ! control-plane ! ! line con 0 no modem enable transport preferred all transport output all line aux 0 transport preferred all transport output all line vty 0 4 exec-timeout 120 0 length 0 transport preferred all transport input all transport output all ! scheduler max-task-time 5000 ! ! end
