Cisco PDM on a PIX 515E
Feb 14, 2007 4 Replies
Jump to replies (4)
Cisco PDM on a PIX 515E open original image
Hi The Cisco PIX 515E is all pretty new to me and to be perfectly honest it's doing my head in. I am sure that the PIX has all the neccessary licenses etc to run the Cisco PDM but when I try and run it the browser window tells me it is 'Loading PIX Device Manager. Please wait...' but then just sits there with an hour glass doing it's thing never actually allowing me to access the PDM
I have attached the sh ver to show that it should work, are there any reasons why this is not starting / working?
pix# sh ver
Cisco PIX Firewall Version 6.3(4) Cisco PIX Device Manager Version 3.0(2)
Compiled on Fri 02-Jul-04 00:07 by morlee
pix up 113 days 21 hours
Hardware: PIX-515E, 128 MB RAM, CPU Pentium II 433 MHz Flash E28F128J3 @ 0x300, 16MB BIOS Flash AM29F400B @ 0xfffd8000, 32KB
Encryption hardware device : VAC+ (Crypto5823 revision 0x1)
0: ethernet0: address is 0014.1c42.ce46, irq 10
1: ethernet1: address is 0014.1c42.ce47, irq 11
2: ethernet2: address is 000d.880f.db68, irq 11
3: ethernet3: address is 000d.880f.db69, irq 10
4: ethernet4: address is 000d.880f.db6a, irq 9
5: ethernet5: address is 000d.880f.db6b, irq 5 Licensed Features: Failover: Enabled VPN-DES: Enabled VPN-3DES-AES: Enabled Maximum Physical Interfaces: 6 Maximum Interfaces: 10 Cut-through Proxy: Enabled Guards: Enabled URL-filtering: Enabled Inside Hosts: Unlimited Throughput: Unlimited IKE peers: Unlimited
This PIX has an Unrestricted (UR) license.
Serial Number: 809181550 (0x303b216e) Running Activation Key: Configuration last modified by enable_15 at 11:45:01.221 WST Wed Feb
14 2007
Cheers
Scott
Your version of Java might be too -new-. PDM doesn't work with the last couple of java releases.
Just a side note http server enable http 192.168.100.0 25.255.255.0 inside
pdm location myhost 255.255.255.255 inside
Am I missing something?
Scott
Only if your host isn't part of 192.168.100.0, or if you are trying to access from outside.
The pdm location command should effectively be considered a comment; it is used for annotating PDM listings, not for any kind of access control.
PIX Device Manager (PDM) versions 3.0(1) , 3.0(2), 4.0(1), and 4.1(1), and IDS Device Manager (IDM) version 5.0(1), are incompatible with Java Plug-in versions 1.4.2_08 and 1.5.0_02 or later. If these Java Plug-ins are used in conjunction with the impacted PDM or IDM releases, the application will not load.
M
