How to rename a vpngroup in Cisco PIX 515e firewall
Sep 18, 2007 2 Replies
Trendkill
I did a quick search and did not find anything that talks about renaming groups. While I can't speak to PIX, you can't rename group like attributes in the router/switch world (by group-like attributes, I mean things you can name like access-lists, etc). I would imagine you have…
Is there a command to do this? If so, what is it? If not, do you have to kill the vpngroup altogether and recreate?
Thanks in advance for all your help.
sax
I did a quick search and did not find anything that talks about renaming groups. While I can't speak to PIX, you can't rename group like attributes in the router/switch world (by group-like attributes, I mean things you can name like access-lists, etc). I would imagine you have to create a new group and then change the commands that reference the old group to the new group's name. Just an educated guess.
