Clarification on VLANS native and management
Mar 12, 2006 6 Replies
Jump to replies (6)
Hello Group,
I am wondering if someone can clarify a configuration for me. I posted earlier regarding this but my post may have confused people. So here goes,
In our company we have a Cisco 871 router (with the 4-port switch built in) a 2950 switch and a 1231 Access Point. We are trying to configure VLANS to support guest internet access and corporate internet access on the Access Point. In all documentation in states for good security to place all trunk ports in a VLAN that is not being used on any other port. Our configuration is as follows.
Router Fastethernet0 switchport trunk native vlan4 switchport mode trunk
Interface VLAN2 (corporate VLAN) IP Address 192.168.10.0 255.255.255.0
Interface VLAN3 (guest internet access) ip address 172.16.29.1 255.255.255.0
interface vlan4 (trunk VLAN) ip address 172.16.99.1 255.255.255.0
VLAN1 is disabled
switch
interfaceFE0/24 (trunk port) switchport trunk native vlan 4 switchport mode trunk
Interface Vlan2 ip address 192.168.10.2 255.255.255.0
Interface VLAN1 is shutdown
Access Point
Inteface BVI1 ip address 172.16.99.11 255.255.255.0
Interface DOT11Radio0.2 (corporate VLAN) bridge group 2
Interface DOT11Radio0.3 (guest VLAN) bridge group 3
Interface DOT11Radio0.4 (native VLAN) bridge group 1
interface Fasteth0.2 bridge-group 2
interface Fasteth0.4 bridge-group 4 encaps dot1q 4 native
So my question is I have the native VLAN on the switch AP and Router set up for VLAN4. SHould the IP Address of the AP's BVI1 interface be in the 192.168.10.0/24 range or is it correct to place it in the VLAN4 range of 172.16.99.0/24. If I change the IP address of the access point to 192.168.10.12/24 everthing seems to work, but if I leave it as
172.16.99.12/24 I can authenticate to the radio but can not pull down an IP address or if I manually assign myself one cannot ping anything at all. Another point is that if I assign the access point an IP address of 192.168.10.12/24 everything seems to work but I can nolonger manage the AP or ping it from a PC on the 192.168.10.0/24 network unless I configure a switch port for swithport access vlan 4 and then use a pc connected to that. Right now I do not have any restrctions on the router in terms of access-lists.
Thanks you very much,
Joe
Hi Joe,
(I guess I should have read all your postings before responding to any of them ... this is why it's best practice to post your followups using the same subject line.)
Anyway ... this is a misconfiguration. It is required that BVI1/bridge-group 1 on the AP be in the native VLAN. In the config below, there is no wired VLAN in bridge-group 1, so nobody on the wired side is going to be able to talk to this AP.
If you want for some reason to call your native VLAN "4" rather than "1" (although see my last posting for a reason why not), then you should configure your AP like this:
interface faste0.4 encaps dot1q 4 native bridge-group 1
Aaron
Hello Aaron,
Sorry about posting twice. So much to learn. Thanks for your help. I guess I am still confused a little regarding the Native Vlan on the access point and want to understand completely. I have researched this extensively but remain a bid cloudy on this. So the question I have is can I assign VLAN1 on the Access Point as native and have the switch port it is attached to as switchport trunk native vlan 4? or must the switch port be switchport trunk native vlan 1 if the Access point's native vlan is 1. A diagram follows; Is this diagram correct?
Thanks,
Joe
2950 Switch __________ Interface Fasteth0/23 (to access point) switchport trunk native vlan 4 switchport mode trunk interface vlan2 ip address 192.168.10.2/24 Interface Fasteth0/24 (to Cisco 871 Router) switchport trunk native vlan 4 switchport mode trunk | | |
Cisco 871 Router
interface Fasteth0
interface vlan2 (corporate users) ip address 192.168.10.1/24 interface vlan 3 (wireless guest access vlan) ip address 172.16.29.1/24 interface vlan4 (Trunk vlan) ip address 172.16.99.1/24)
Cisco 1231 AP (Connected to switch Fasteth0/23 port) interface Dot11Radio0.2 bridge-group 2 interface Dot11Radio0.3 bridge-group 3 interface Dot11Radio0.4 encaps dotQ 4 native bridge-group 1 interface Fasteth0.2 bridge-group 2 interface Fasteth0.3 bridge-group 3 interface Fasteth0.4 encaps dotQ 4 native bridge-group 1 interface BVI1 ip address 172.16.99.12/24
Hi Joe,
~ Sorry about posting twice. So much to learn. Thanks for your help. I ~ guess I am still confused a little regarding the Native Vlan on the ~ access point and want to understand completely.
No worries; I've spent plenty of time being confused on this point myself ...
~ I have researched this ~ extensively but remain a bid cloudy on this. So the question I have is ~ can I assign VLAN1 on the Access Point as native and have the switch ~ port it is attached to as switchport trunk native vlan 4? or must the ~ switch port be switchport trunk native vlan 1 if the Access point's ~ native vlan is 1.
OK, so here's the key:
If you are doing 802.1q trunking, then the VLAN IDs for each frame are carried in the frame header. If one side is sending out frames tagged VLAN 47 but the other side is not configured for VLAN 47, then those frames will go into the bit bucket. So VLAN n on one side of the trunk has to match up to VLAN n on the other side of the trunk.
BUT there is an exception: the "native" VLAN, meaning the UNTAGGED VLAN [*]. Since the native VLAN is untagged, then one side of the trunk can call the native VLAN 1 and the other side can call the native VLAN 4, and neither will be any the wiser ... the number assigned to to the NATIVE VLAN is only of local significance.
~ A diagram follows; Is this diagram correct?
Yes, I believe this is correct (but for one small issue[**]):
BVI1 on the AP is 172.16.99.12/24 bridge-group 1 on the AP bridges to FastE0.4 which is configured for "native VLAN4"
So the AP is in subnet 172.16.99/24 in the native VLAN.
The switch is configured with native VLAN "4" on both the trunk to the AP and the trunk to the 871.
The 871 is configured with native VLAN 4 and with 172.16.99.1/24 on interface VLAN4.
Therefore, I predict that 172.16.99.1 and 172.16.99.12 will be able to ping each other.
Cheers,
Aaron
Hello again Aaron,
F> Hi Joe,
Hello again Aaron,
F> Hi Joe,
Hello again Aaron,
F> Hi Joe,
