Help
Mar 27, 2005 1 Replies
i need help and thank you helping me in advance.
here is my issue: have 3 routers 1 are 2 okay but the 3rd one when ip put ip routing and run the show ip route it doesn't show anything no ip. but if run the show run i would see routing table. other routers they fine. i don't if interfaces of the router is bad or not....i configure both ethern and serial. Cisco 2501 and 2514 Khalif
Did you config the config?
