Frame relay:Long ping delay
Sep 11, 2006 1 Replies
I have setup 2 routers connected to a frame relay switch.When i ping locally,it give me a long delay and remotely,the delay is half of the local router.What can cause this ??? Remote PING
Router#ping 172.21.3.2
Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 172.21.3.2, timeout is 2 seconds: !!!!! Success rate is 100 percent (5/5), round-trip min/avg/max = 32/32/32 ms
Locall PING :
Router#ping 172.21.3.1
Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 172.21.3.1, timeout is 2 seconds: !!!!! Success rate is 100 percent (5/5), round-trip min/avg/max = 64/65/72 ms Router#
Hello,
Can you issue a sh interface and show frame-relay pvc and post the results.
vreyesii
squid3570 wrote:
