help!!! ping losss 80%
Jun 01, 2006 5 Replies
Jump to replies (5)
Hi!! I have a cisco 2811 router with adventerprisek9 12.4 ios version, I have all configured, ios firewall, ips etc... The current ports Im using it are FA0/0 which is for lan, and FA0/1 which is for wan... I got nat to one ip which is also used for the webvpn and vpn connections, my company got around 50 users.
The problem its when I ping any outside station I got a ping succcess of 80% ... is like 3 in 3 seconds im loosing 1 datagram. Internally I ping sucesseful without any problems at all... what could it be this problem? I can ping my gateway IP and its 100% but after that its always 80% ... Really need help! any advice? thanks
e.g. DEgateway#ping Protocol [ip]: Target IP address: 158.43.128.72 Repeat count [5]: 100 Datagram size [100]: Timeout in seconds [2]: Extended commands [n]: Sweep range of sizes [n]: Type escape sequence to abort. Sending 100, 100-byte ICMP Echos to 158.43.128.72, timeout is 2 seconds: .!!!!!!!!!!!!!!!!!!!!!!!!!!!!!.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!.!!!!!!!!!!!!!!!!!!!!!!!!!!! Success rate is 97 percent (97/100), round-trip min/avg/max = 20/21/28 ms DEgateway#ping Protocol [ip]: 158.43.128.72 % Unknown protocol - "158.43.128.72", type "ping ?" for help DEgateway#ping Protocol [ip]: Target IP address: 158.43.128.72 Repeat count [5]: 500 Datagram size [100]: Timeout in seconds [2]: Extended commands [n]: Sweep range of sizes [n]: Type escape sequence to abort. Sending 500, 100-byte ICMP Echos to 158.43.128.72, timeout is 2 seconds: !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!.!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!.!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!.!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!.!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!.!!!! Success rate is 97 percent (488/500), round-trip min/avg/max = 20/23/40 ms DEgateway#
Sounds like a circuit issue. From the router, ping the next hop on the wan circuit and see if you still get ping loss. If you do, you've found the problem.
I forgot to include, this is the output of the interface which connects to the outside world, my connection is:
LAN=A6-------------------------=A6CISCO2811=A6-publicip-----------=A6ROUTER= .ISP=A6------LEASEDLINE
The line btw cisco2811 and isp router its working at half duplex, I have fitted the router 3weeks ago. Everything there is in my premises.
DEgateway#sh controllers fa0/1 Interface FastEthernet0/1 Hardware is MV96340 HWIDB: 46E8F410, INSTANCE: 46E904F0, FASTSEND: 4343B97C, MCI_INDEX: 0
Aggregate MIB Counters
---------------------- Rx Good Bytes: 151816324 Rx Good Frames: 353042 Rx Bad Bytes: 129824 Rx Bad Frames: 1455 Rx Broadcast Frames: 2816 Rx Multicast Frames: 1100 Tx Good Bytes: 333571839 Tx Good Frames: 405116 Tx Broadcast Frames: 10 Tx Multicast Frames: 0 Rx+Tx Min-64B Frames: 175318 Rx+Tx 65-127B Frames: 164684 Rx+Tx 128-255B Frames: 73991 Rx+Tx 256-511B Frames: 30312 Rx+Tx 512-1023B Frames: 35986 Rx+Tx 1024-MaxB Frames: 279322 Rx Unrecog MAC Ctrl Frames: 0 Rx Good FC Frames: 0 Rx Bad FC Frames: 0 Rx Undersize Frames: 0 Rx Fragment Frames: 0 Rx Oversize Frames: 0 Rx Jabber Frames: 0 Rx MAC Errors: 0 Rx Bad CRCs: 0 Tx Collisions: 1455 Tx Late Collisions: 0
PHY Registers
------------- Register 0x00: 1000 782D 0040 61E4 01E1 0021 0004 2001 --More-- camocas wrote:
Can you post a Show Interface and the Logs?
camocas wrote:
ER.ISP=A6------LEASEDLINE
