Hello, In the lab to which I've remote access is router with eth0 intf connected to the wic card on the other router (4 fast ethernet ports switch, 4FESW) I can't make line protocl up - it only is up for a while during IP address change as below presented. Mabye problem is with 'Unknown Speed' or 'lost carrier' ? On the fast ethernet port I have probably right settings Speed:10, Duplex: auto Have you any idea what is wrong? Thanks for any help. Regards, Andrew
Router#conf t Enter configuration commands, one per line. End with CNTL/Z. Router(config)#int eth1 Router(config-if)#ip address 1.1.1.1 255.0.0.0 Router(config-if)#exi Router(config)#exi Router#sh
*Mar 23 22:37:23.071: %SYS-5-CONFIG_I: Configured from console by console Router#sh
*Mar 23 22:37:24.147: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet1, changed state to up Router#sh
*Mar 23 22:37:25.527: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet1, changed state to down Router#sh int eth1 Ethernet1 is up, line protocol is down Hardware is PQUICC_FEC, address is 000f.231e.2c4d (bia 000f.231e.2c4d) Internet address is 1.1.1.1/8 MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec, reliability 191/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Full-duplex, Unknown Speed ARP type: ARPA, ARP Timeout 04:00:00 Last input never, output 00:00:08, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 input packets with dribble condition detected 198203 packets output, 11900460 bytes, 0 underruns 198168 output errors, 0 collisions, 9 interface resets 0 babbles, 0 late collision, 0 deferred 198168 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out Router#
