Errors
Feb 06, 2007 2 Replies
Hi All, I connected PIX firewall and internet router using cross cable,iam experiencing input errors and ignored in ethernet interface router.
Received 150 broadcasts, 0 runts, 0 giants, 962 throttles 44616 input errors, 0 CRC, 0 frame, 0 overrun, 44616 ignored
Could anyone provide solution for this issue,thanks in advance
Regards, Suresh
Duplex/speed mismatch on the interface. Do you control the device you are connecting it to? If so verify the port settings are the same on both devices...
Not duplex this time.
These errors are NOT hardware errors but are caused by the router being too busy to process the received packets and "Ignoring" them. There are also interrupt throttles which is the router trying to protect itself so that it can do housekeeping.
Troubleshoot Router CPU.
please post
sh ver sh proc cpu ! ideally when busy
