Cisco Pix 515 Question - Hyperterminal cut/paste
Feb 06, 2007 1 Replies
How does one completely replace the code on a Pix 515?
I saw someone do this using Hyperterminal with Cut/Paste a few years ago, but cannot reproduce.
Thanks,
G
You would need to set your terminal emulator to pause at least one second after sending each line. If the configuration is at all big, then you might need 2 or 3 seconds after each line. The buffers on the PIX are not very big.
Also, if you use copy + paste, then you are going to end up with invalid passwords, at least if what you are copying is "show terminal".
The "proper" way to replace the configuration is to clear the configuration, then configure the tftp-server command, and then use the "copy" command to copy the new configuration in from a tftp server.
If you are using PIX 7.x then you could instead use a tftp server and copy the configuration into a named file, and then tell the PIX to use that file as the current configuration.
