ds3 scrambling
Aug 08, 2006 0 Replies
Hi all, I have the following situation:
  1. An OC12 comes into the building terminating at a Fujitsu SONET mux
  2. From the mux I take a coax pair to a 3800 router for a subrate DS3 interface
It seems that at time there a syncing issues. A few times the router reloaded on its own and the circuit would not come up (Up/Down state on serial interface). Putting the t3 controller into local loopback and then taking off the loopback bought the circuit up.
Errors are seen when the line protocol is down:
Output queue: 0/40 (size/max) 5 minute input rate 13121000 bits/sec, 1759 packets/sec 5 minute output rate 2298000 bits/sec, 1375 packets/sec 9987450 packets input, 190364488 bytes, 0 no buffer Received 0 broadcasts, 1 runts, 3 giants, 0 throttles 6801436 input errors, 6801433 CRC, 2930683 frame, 1720413 overrun,
0 ignored, 5010533 abort
After the looping all errors cease.
Would scrambling help a syncing issue like this?
