How can one TFTP download the syslog from the DRAM of a router.? What are the instructions?
Downloading syslog from DRAM?
Mar 07, 2009
I don't think that you can. sh log or better is to use a syslog server and send all of the log messages to it as they arise. I suppose that there might be a way to get the log using snmp. Good luck working that out.
sh log
trs80 schrieb:
Try a combination with "archive" and "kron"
~ How can one TFTP download the syslog from the DRAM of a router.? What are ~ the instructions? ~
router#show log | redirect tftp://ip.addr.or.hostname/FILENAME.EXT
Not noticed that one - thanks. Once again:))
