Checking DRAM slots on a 2610XM
Apr 25, 2008 4 Replies
Checking DRAM slots on a 2610XM open original image
Is there an IOS command to check what DRAM slots are currently being used and how much DRAM is in them? The router currently has 96MB installed and I need to get 128MB.
Thanks
do not know
see
Upgrading System Memory, Internal Flash, and Boot ROM in Cisco 2600 Series Routers
Table 2 3.3-V SDRAM Part Numbers
Memory Size 3.3-V SDRAM 32 MB 15-4108-xx
64 MB 15-4508-xx
128 MB 15-8693-xx
by looking at the memory size available, then I would think you have one 64 MB DIMM and one 32 MB DIMM
or perhaps just show c2600 | inc DIMM
HUB#sh c2600 | inc DIMM DIMM Slot 0: DIMM Type : Dual-bank DIMM Size : 32MBytes DIMM Slot 1: DIMM Type : Dual-bank DIMM Size : 32MBytes
