When I run "show hardware" on my 2821 I see "1 Virtual Private Network (VPN) Module". But I am not clear if that is part of the standard 2821 or this refers to the AIM-VPN/SSL-2 module. Can anyone lend insight? Thanks.
Cisco 2821 (revision 53.51) with 249856K/12288K bytes of memory. Processor board ID FTX1004C04P
2 Gigabit Ethernet interfaces
1 Virtual Private Network (VPN) Module DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
