Disabling LED's on Cisco Aironet AP#s
Apr 11, 2005 2 Replies
is there a way to disable the LED's on the Cisco Aironet AP's?
Martin Bodenstedt schrieb:
AFAIK only in "hardware": with a piece of tape glued over the LED's :-(
"led flash disable" command only ends the flashing pattern for localizing an AP. The AP returns to the normal LED flashing pattern indicatin traffic on the interfaces.
That's what I thought. But thanks anyway...
