Newbie: Cisco Routing Subnet Zero - Inconsistent Address and Mask
Apr 11, 2005 3 Replies
Jump to replies (3)
Hi All, Im new to cisco and I am trying to configure a new cisco 1721 router. My intention is to keep our 2 networks more or less seperate except to send small amounts of data to and from each other when necessary (i.e. keep network traffic seperate). One network is using the range
192.168.1.1 - 192.168.1.254 with the sunet mask of 255.255.255.0 and uses a DHCP server. The other network, which hasn't been setup yet, I would like to use the range 192.168.2.1 - 192.168.2.254 with the same subnet mask of 255.255.255.0 but IP's will be statically assigned.
I need the DHCP'ed PC's to be able to access the statically assigned PC's on the other network for data sharing.
As I'm new to cisco I was hoping someone would be able to give me some pointers as to what needs to be configured on the router.
So far what I have done is: Enabled fastethernet0 with a no shutdown command Issued ip subnet-zero command in the config section Set the ip address of the interface to 192.168.2.1 255.255.255.0 'Tried' to map route to switch using 192.168.2.1 255.255.255.0
192.168.2.2
This last command fails and returns the message inconsistent address and mask. Whilst experimenting I got it to map successfully using the mask 255.255.255.255 but as I want both networks on the subnet
255.255.255.0 I need to get it working with the other subnet.
From what I've read I understand that cisco, by default, does not allow
zero subnets although a ip subnet-xero command show allow this. I've tried this and am still getting an inconsistent address and masak message.
Anyone got any ideas??
Looks to me like you are not putting the correct route statement in, however:
If the networks 192.168.2.0 + 192.168.1.0 are directly connected to the router then you dont need to add a route statement. But if its not then your route statement would look like this: ip route 192.168.2.0 255.255.255.0 [interface]
If you type: "show ip route" What is the output of the command.
Do you have an extra WIC-1ENET on the 1721 and where is the switch connected to?
Regards,
Rob
The "inconsistent address and mask" message means that the address part of a static route included some bits that are masked off by the mask. E.g.
ip route 192.168.2.1 255.255.255.0 ...
the .1 at the end of the address is masked off by the .0 in the mask. This is an error check that Cisco added, to catch cases where you used a too-large mask. The correct statement would be:
ip route 192.168.2.0 255.255.255.0 ...
But, as the other poster said, you don't need to create static routes for subnets that are ddirectly connected to the router.
You're not using the zero subnet, so why do you think this is relevant? In fact, you're not using *any* subnets, you're using ordinary class C address blocks.
Thanks for your help. The main problem I was having was not knowing about the interface part of the ip route statement, and I was trying to figure out the ip address of the interface rather than the name. Anyhow, despite a crash of the IOS which had to be reinstalled, I have now got it working as I wanted it to be working.
