Disable RX on port
Feb 15, 2006 1 Replies
Disable RX on port open original image
Can you provide the command if there is one to disable the RX on the port defined as a SPAN destination?
Example:
If I set module 3 port 24 to be a SPAN destination, I want to know if I can turn off the receive so the port stays active even if no data is coming back.
I am running CiscoIOS on a SUP720.
see Cisco doc
monitor session 1 source interface {both | rx | tx} monitor session 1 destination interface fastethernet 3/24
You cannot configure rx on the destination port AFAIK
