How to best use IDSM in promiscuous mode?
Sep 20, 2007 0 Replies
Hi folks
I need some input and ideas how to best set up my IDSM2 module. Today I have the module set up to capture traffic from the 6513 using SPAN in both directions and two different firewalled VLANs as sources. The destination is data-port 1 on the IDSM. This setup is working fine but I'm curious as how to best use the second data-port. Our 6513 runs IOS 12.2(18)SXF3 and has a limit of only one SPAN session set up to capture an entire VLAN in both directions. My idea was to use the second data-port as SPAN destination for our external/non-firewalled VLAN, but this isn't allowed. Does anyone have or had a similar problem? Would using a VLAN access list with data-port 2 as destination be an option or are the dual IDSM interfaces mainly used for inline mode?
Regards Fredrik Hofgren
