Csico 804 ISDN-6-NO_TIMER Errors
Feb 19, 2006 1 Replies
Can any one advise on how to correct this issue: ISDN-6-NO_TIMER: errors on Cisco 804 ISDN routers. Thanks in advance.
Error: ISDN-6-NO_TIMER: No Free Timer Entry, caller 0x5185A0, timers used 2 ISDN-6-INVALID_TIMER: LIF_StartTimer: Invalid Timer Handle, caller 0x518BD8 handle 0 ISDN-4-ISDN_UNEXPECTED_EVENT: calltrkr_call_cleared: no idb : Occurred at ../isdn/isdnintrfc.c:28260
Router Info:
Cisco Internetwork Operating System Software IOS (tm) C800 Software (C800-Y6-MW), Version 12.1(3)XG4, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1) TAC:Home:SW:IOS:Specials for info Copyright (c) 1986-2001 by cisco Systems, Inc. Compiled Fri 23-Feb-01 16:05 by detang Image text-base: 0x000EE000, data-base: 0x00655000
ROM: TinyROM version 1.4(1) Router uptime is 14 minutes System returned to ROM by power-on System image file is "flash:c800-y6-mw.121-3.XG4"
Cisco C804 (MPC850) processor (revision 1) with 43464K bytes of virtual memory. Processor board ID JAD0534012X CPU part number 0x2101 Bridging software. Basic Rate ISDN software, Version 1.1.
2 POTS Ports
1 Ethernet/IEEE 802.3 interface(s)
1 ISDN Basic Rate interface(s)
4M bytes of physical memory (DRAM)
8K bytes of non-volatile configuration memory
8M bytes of flash on board (4M from flash card)
Configuration register is 0x2102
Config: Running Config Current configuration: ! version 12.1 no service pad service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname Router ! ! ! ! ! ! ! dial-peer voice 1 pots call-waiting ring 0 port 1 destination-pattern ******* ! dial-peer voice 2 pots call-waiting ring 0 port 2 destination-pattern ******* ! pots country US ! no ip subnet-zero no ip source-route ! ip dhcp pool DHCPPoolLAN_0 network 192.168.1.0 255.255.255.0 dns-server 209.***.***.8 default-router 192.168.1.1 ! ip name-server 205.***.*.65 ip name-server 205.***.*.65 isdn switch-type basic-ni ! ! ! interface Ethernet0 ip address 192.168.1.1 255.255.255.0 ip access-group 121 in no ip proxy-arp ip nat inside ! interface BRI0 no ip address no ip redirects no ip unreachables encapsulation ppp isdn switch-type basic-ni isdn spid1 **********1111 isdn spid2 **********1111 no cdp enable ppp authentication chap pap callin ppp multilink ! interface Dialer0 no ip address no cdp enable ! interface Dialer1 description ISP ip address negotiated ip access-group 121 in no ip proxy-arp ip nat outside encapsulation ppp no ip split-horizon dialer remote-name Cisco1 dialer pool 1 dialer idle-timeout 300 dialer string ******* class DialClass dialer hold-queue 10 dialer load-threshold 1 either dialer-group 1 pulse-time 0 ppp authentication chap pap callin ppp chap hostname **************** ppp chap password 7 01070E014B0A151C ppp pap sent-username ********************* password 7 **************** ppp multilink ! ip nat inside source list 1 interface Dialer0 overload ip nat inside source list 18 interface Dialer1 overload no ip http server ip classless ip route 0.0.0.0 0.0.0.0 Dialer1 ip route 0.0.0.0 0.0.0.0 Dialer0 ! ! map-class dialer DialClass access-list 1 permit any access-list 18 permit 192.168.0.0 0.0.0.255 access-list 20 permit 192.168.1.0 0.0.0.255 access-list 20 deny any access-list 110 deny ip 10.0.0.0 0.255.255.255 any access-list 110 deny ip 172.16.0.0 0.15.255.255 any access-list 110 deny ip 192.168.0.0 0.0.255.255 any access-list 121 deny udp any eq netbios-dgm any access-list 121 deny udp any eq netbios-ns any access-list 121 deny udp any eq netbios-ss any access-list 121 deny tcp any eq 137 any access-list 121 deny tcp any eq 138 any access-list 121 deny tcp any eq 139 any access-list 121 permit ip any any time-range TIME dialer-list 1 protocol ip permit ! line con 0 exec-timeout 0 0 transport input none access-list 121 permit ip any any time-range TIME dialer-list 1 protocol ip permit ! line con 0 exec-timeout 0 0 transport input none stopbits 1 line vty 0 access-class 20 in exec-timeout 0 0 password ***** login transport output none line vty 1 4 exec-timeout 0 0 login ! ! time-range TIME periodic daily 0:00 to 23:59 ! end
  1. %ISDN-6-NO_TIMER: No Free Timer Entry, caller [hex], timers used [dec]
The ISDN protocol cannot start new timers for its operation. This message may indicate a low memory condition.
Recommended Action: Enter the show isdn mem and show isdn status commands to gather debugging information. Reduce other system activity to ease the memory demands on the system.
