Csico 3640 => MTU/ISIS/MPLS
Feb 08, 2009 3 Replies
Jump to replies (3)
Hi
i want change the MTU of my MPLS interface on a PE cisco 3640.
mpls mtu 1548
and same on the P router
but after this, ISIS don't see any equipement ...
anyone know why ?
thanks
On an Etherenet or Fast Ethernet interface the maximum MTU size is 1500. The maximum MPLS MTU size is 1476 because of the additional IP and MPLS header (20 byte IP header and 4-byte MPLS header.) If this is a serial interface you can use larger MTU sizes, but it must be set to the same value on BOTH sides. If one side is set to 1500 and the othe is set ot 1548, the side with an MTU of 1500 will drop any packet that it receives that is larger than that value.
OSPF has a special interface configuration command
ip ospf mtu-ignore
without it OSPF doesn't work if mtu of one device doesn't match mtu on other devices. I guess IS-IS might have something similar.
But mpls mtu 1548 is not enough. You need your hardware to support lager packets too. And here we come to the bad thing: FastEthernet interfaces on 3640 doesn't allow packets to be larger than 1500 bytes.
Good news:
mpls mtu N
automatically increases interface mtu. Just make sure, your switch supports large mtu.
