CRT - scripting question
Jul 20, 2005 1 Replies
Hi Erik,
You may wish to investigate -
Backing Up Cisco Configs via TFTP Free Scripts:
as well as the VanDyke Software Scripting Forum:
Hope this helps.
Brad Reese BradReese.Com Cisco Repair Service Experts
1293 Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 U.S. Toll Free: 877-549-2680 International: 828-277-7272 Website:
CRT - scripting question open original image
Hi
I am not a good programmer and need some advice. Can anyone give me advice on how best to automate repetitive router management tasks using secureCRT. I never woked in a telco environment so never really needed to script and automate tasks. Now have to deal with very large networks and would like to make life easier. I am using secure crt to ssh to a server from where we can reach cisco routers using standard telnet. For starters I would like to build a list of wan addresses and let crt telnet to each and save the config to a tftp server. Will try more later - like make config changes for a number of devices etc.
I use the standard login script to get me in on the ssh server without any keystrokes - works fine, How do I now create a scritp with a list of routers that secureCRT can use once it connects to the server to auto telnet to miltiple devices and issue a copy...tftp etc command. Or is it the other way round - should one write a script that calls crt. I notice that van dyke have a couple of sample scripts - I am not sure how they should be compiled or called from CRT
Any advice will be appreciated.
erik
