Troubleshooting port redirection on PIX 501 using Syslog - PDM3.0.jpg (0/1)
Jul 20, 2005 3 Replies
Jump to replies (3)
I have a PIX 501 and want to redirect VNC from the outside to a host on the inside. I've googled this & been to the Cisco website & still having no luck. I setup a Syslog server to help in troubleshooting this problem. Connectivity to the outside (web, outbound VNC connections) is not a problem. When I look at the logs I see the following: Jul 20 2005 14:43:27 192.168.1.182 : %PIX-7-710005: TCP request discarded from xxx.xxx.xxx.xxx/62372 to outside:xxx.xxx.xxx.xxx/5900
I used PDM 3.0 to setup the access rules. I've included a small screen shot as well as a running configuration. I'm very new to Cisco gear, but used Linux for my firewalls & VPNs for years. Any help would be appreciated.
Thanks JA Result of firewall command: "sh run conf" : Saved : PIX Version 6.3(4) interface ethernet0 auto interface ethernet1 100full nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password XXXXXXXXXXXX encrypted passwd XXXXXXXXXXXXXXXX encrypted hostname XXXXXXXXXXX domain-name ciscopix.com fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names name 192.168.1.240 Syslogger access-list outside_access_in permit tcp any eq 5900 host Syslogger eq
5900 log 7 pager lines 24 logging on logging timestamp logging console informational logging buffered informational logging trap debugging logging device-id ipaddress inside logging host inside Syslogger mtu outside 1500 mtu inside 1500 ip address outside xxx.xxx.xxx.xxx 255.255.255.248 ip address inside 192.168.1.182 255.255.255.0 ip audit info action alarm ip audit attack action alarm pdm location Syslogger 255.255.255.255 inside pdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 1 0.0.0.0 0.0.0.0 0 0 static (inside,outside) 192.168.1.182 192.168.1.182 netmask
255.255.255.255 0 0 static (inside,outside) Syslogger Syslogger netmask 255.255.255.255 0
0 access-group outside_access_in in interface outside route outside 0.0.0.0 0.0.0.0 64.5.213.33 1 timeout xlate 0:05:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server LOCAL protocol local http server enable http 192.168.1.0 255.255.255.0 inside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable telnet 192.168.1.0 255.255.255.0 inside telnet timeout 5 ssh 192.168.1.0 255.255.255.0 inside ssh timeout 5 management-access inside console timeout 0 dhcpd address 192.168.1.2-192.168.1.129 inside dhcpd lease 3600 dhcpd ping_timeout 750 dhcpd auto_config outside terminal width 80 Cryptochecksum:4213557af54970a204d89fa90d55d411 : end
If the public IP address is the IP address of the outside interface, then the syntax is:
access-list outside_access_in permit tcp any interface outside eq 5900 static (inside,outside) tcp interface 5900 192.168.1.X 5900
If not, then use:
access-list outside_access_in permit tcp any host X.X.X.X eq 5900 static (inside,outside) tcp X.X.X.X 5900 192.168.1.X 5900
On Wed, 20 Jul 2005 22:47:02 +0300, "Jyri Korhonen" wrote: As the public IP is the IP address of the outside interface, I tried the first suggestion without success. I decided to start from scratch & reset the PIX 501 to the factory default configuration, and entered the commands again. I still can't connect, but, I am receiving the following message from syslog
Jul 21 2005 14:01:16: %PIX-2-106001: Inbound TCP connection denied from 142.xxx.xxx.xxx/63072 to 64.xxx.xxx.xxx/5900 flags SYN on interface outside
What am I doing incorrectly???
Here's the running config as well
Building configuration... : Saved : PIX Version 6.3(4) interface ethernet0 auto interface ethernet1 100full nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password XXXXXXXXXXXX encrypted passwd XXXXXXXXXXXXXX encrypted hostname pixfirewall domain-name ciscopix.com fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names access-list outside_access_in permit tcp any interface outside eq 5900 pager lines 24 logging on logging timestamp logging trap warnings logging host inside 192.168.1.240 mtu outside 1500 mtu inside 1500 ip address outside 64.xxx.xxx.xxx xxx.xxx.xxx.xxx ip address inside 192.168.1.182 255.255.255.0 ip audit info action alarm ip audit attack action alarm pdm location 192.168.1.240 255.255.255.255 inside pdm logging debugging 100 pdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 1 0.0.0.0 0.0.0.0 0 0 static (inside,outside) tcp interface 5900 192.168.1.240 5900 netmask
255.255.255.255 0 0 route outside 0.0.0.0 0.0.0.0 64.xxx.xxx.xxx 1 timeout xlate 0:05:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server LOCAL protocol local http server enable http 192.168.1.0 255.255.255.0 inside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable telnet 192.168.1.0 255.255.255.0 inside telnet timeout 5 ssh timeout 5 console timeout 0 dhcpd address 192.168.1.2-192.168.1.129 inside dhcpd lease 3600 dhcpd ping_timeout 750 dhcpd auto_config outside terminal width 80 Cryptochecksum:635610f7eb18dfe873cc2425484d7ee4 : end [OK]
On Wed, 20 Jul 2005 22:47:02 +0300, "Jyri Korhonen" wrote: Found the problem. I forgot to do a access-group outside_access_in in interface outside command. Once I did that it worked fine.
Thanks again for the help!!!!
