Create a PEAP Certificate using OpenSSL for use with IAS on an Aironet1200
Aug 25, 2005 2 Replies
Hi Wil,
You may wish to investigate Cisco Wireless TAC Case Solution # K17306437.
How to enable Protected Extensible Authentication Protocol ( PEAP ):
http://129.41.16.73/wireless/showcase?case=K17306437 Hope this helps.
Brad Reese BradReese.Com Cisco Repair Service Experts
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA/Canada Toll Free: 877-549-2680 International: 828-277-7272 United Kingdom: 44-20-70784294
Has anyone been able to actually make this happen? Looks like there are a couple of "Bag Attributes" that IAS requires for a PEAP certificate. I for the life of me cannot get a certificate generated using OpenSSL.
I appreciate the info, unfortunately that is client side... The client side will be handled via PKI when all is complete.
I suppose this is probably more of an OpenSSL question, but I figure enyone here that has used PEAP has gone through this process.
Basically I need to set the Bag Attributes as follows:
Crypto Graphic Service Provider (oid=1.3.6.1.4.1.311.17.1) set to 'Microsoft RSA SChannel Cryptographic Provider'
LocalKeySet (oid=1.3.6.1.4.1.311.17.2) set to an empty string.
Wil my 3¢
wrote:
