copy command without confirmations
May 02, 2007 1 Replies
is it possible to use the copy command (e.g. copy tftp://10.0.0.1/config.cfg system:running-config) without having to confirm server and destination file name. I have had a look at the command reference, but cant see any command line options to achieve this.
thanks
Neil
snipped-for-privacy@hotmail.com schrieb:
"file prompt quiet" If you don't specify all parameters IOS will try to use defaults!
Bernd
