CMS problem with ftp
May 24, 2005 0 Replies
Hi, I have the CMS module on my 6509 with sup1/msfc2. My problem is easy: all works (http, smtp, pop3, ...), except ftp.
a easy example:
I have a server on ipA. And I want to load balance ipB to ipA.
I connect to ipA to ftp service (ftp works): # ncftp ipA ncftp / > ls -al [...] ncftp / > pas passive off ncftp / > ls -al [...] ncftp / > pas passive on ncftp / > ls -al [...]
So, it works.
Now I want to use CMS to load balance ipB to ipA: # ssh root@ipA # ifconfig lo:0 ipB netmask 255.255.255.255
then: # conf t module ContentSwitchingModule 3 vlan XXX client ip address ipC 255.255.255.0 vlan YYY server ip address ipD 255.255.255.0 probe ICMP icmp interval 30 retries 2 failed 60 receive 20 serverfarm TEST_WWW no nat server no nat client real ipA inservice probe ICMP vserver TEST_WWW virtual ipB any serverfarm TEST_WWW persistent rebalance inservice end
I can ping ipB, I can use http, smtp, pop3 on ipB but: # ncftp ipB ncftp / > pas passive on ncftp / > ls -al [...] ncftp / > pas passive off ncftp / > ls List failed.
I have no firewall.
Worst:
conf t mod con 3 vserver TEST_WWW no in virtual ipB tcp ftp service ftp in
and now, nothing works !
# ncftp ipB NcFTP 3.1.5 (Oct 13, 2002) by Mike Gleason ( snipped-for-privacy@ncftp.com). Connecting to ipB... # telnet ipB 21 Trying ipB... Connected to ipB. Escape character is '^]'. ^] telnet> q Connection closed. #
Any idea ?
Thanks in advance Marcelo
#sh mod Mod Ports Card Type Model Serial No.
--- ----- -------------------------------------- ------------------ ----------- 1 2 Cat 6k sup 1 Enhanced QoS (Active) WS-X6K-SUP1A-2GE XXXXXXXXXXX 2 8 8 port 1000mb ethernet WS-X6408-GBIC XXXXXXXXXXX 3 0 SLB Application Processor Complex WS-X6066-SLB-APC XXXXXXXXXXX
Mod MAC addresses Hw Fw Sw Status
--- ---------------------------------- ------ ------------ ------------ ------- 1 0002.fcbc.8f78 to 0002.fcbc.8f79 7.0 5.3(1) 12.1(22)E2 Ok 2 0030.a338.a638 to 0030.a338.a63f 2.3 4.2(0.24)VAI 8.3(0.111)TF Ok 3 0011.5ceb.5e5a to 0011.5ceb.5e61 1.7 4.1(1) Ok
Mod Sub-Module Model Serial Hw Status
--- --------------------------- --------------- --------------- ------- ------- 1 Policy Feature Card WS-F6K-PFC SAD05050906 1.1 Ok 1 Cat6k MSFC 2 daughterboard WS-F6K-MSFC2 SAD05050KLM 1.2 Ok
Mod Online Diag Status
