FTP passive problem with PIX 515E
Mar 07, 2006 5 Replies
Jump to replies (5)
Sorry for my very bad english. ¿Can you speak spanish?
I publish a Microsoft FTP Server through Cisco PIX 515E with static PAT. In active (port) mode works fine, because in passive mode any command receive response and a time out is received. I use fixup command for ftp to port 21. The static pat redirect ports tcp-udp 20 and 21, and access rules permit trafic to ports TCP-UDP 20 and 21.
What is my problem?
Very thanks, Diego Fernández
Fine.
Drop static and access-list for port 20. Then fixup can work. Drop static and access-list for protocol udp.
Hi, I delete de static access-list for port 20. I delete de static access-list for protocol udp.
In active mode works fine because in passive mode not work.
Can help me? Very thanks.
Diego Fernández
PD. Sorry for my bad english.
"Lutz D>> In active (port) mode works fine, because in passive mode any command
Then your pix or your config is broken. You may post the relevant part of your config, if possible.
How UDP is related to FTP (either active, or passive)?
Thanks to all. FTP is working. The problems is that the FTP Server had 2 Ip's, because only one is public though PIX. When de FTP server send port command (in passive mode) is sendind with IP not published.
Very thanks for your interesting.
Sorry for my very bad english. Diego Fernández
"Diego Fernández" escribió en el mensaje news:dukb0i$qef$ snipped-for-privacy@nsnmpen3-gest.nuria.telefonica-data.net...
