I have a problem with my fire wall
Nov 08, 2006 6 Replies
Jump to replies (6)
hi, I'am using firebox for my firewall.My problem is that i want to connect to a system in domain in side a firewall from outside using a VPN.Using VPN I'm able to connect(what I mean is that I did not get any connection problem or error) but I'm not able to ping the system that I want to connect but I'm able to ping my production server only.What may be the problem .
Once you setup the VPN you still need to create rules for that VPN User/Office network or you won't get anywhere on the LAN.
Hi Vikas,
Which Version of IOS are you runing on Firebox500
After connwecting the VPn you still have to open the internal Ip for external users.
CK
vikas wrote:
The firebox devices don't run IOS.
He was already told that the VPN still requires you to map rules for internal access.
So that means Firebox does not need anykind of OS or Firmware to be installed on hardware box.It is running without the base. Go through for details:
CK
Leythos wrote:
I associate IOS with Cisco, not WatchGuard or other Linux/BSD firmware system.
The system you ping is blocking ICMP.
