Help CiscoWorks 2.5 and CMS devices
Jul 09, 2005 1 Replies
Hi all,
I have a newly installed Ciscoworks LMS 2.5 server on a Windows 2003 platform. We are having an issue with discovering switches that are configured in a cluster via Cluster Management Suite. Because of the ability to manage several switches via a single IP via the CMS commander, non of the other switches have an IP, thus no DNS/RDNS for Ciscoworks to resolve and discover. All switches have SNMP and CDP configured and operational.
My question, is there a way to discover all the other switchs that are managed by a CMS commander? will it be necesary to assign IP's to all the switches that do not have IP's assigned, but are visible and available via the CMS?
The switches in question are as follows:
CMS commander is a Catalyst 3550 CMS members are a variety of 2950's and 2900XL's
Thanks
Frank
unh0lyatswdotrrdotcom
Your going to need to open a case with the TAC, the new release is buggy as hell make sure you check and see if there are any updates, if you upgraded instead of new install your most likely hosed.
UnH0Ly wrote:
