Cisoc 4500M with broadband
Nov 21, 2005 1 Replies
I need a little help with this one. I have a 4500m that I use as a broadband router. The issue I am having is that I can only get download speeds of 500K but when I use the linksys router I can achieve 5 meg download speeds. I think everything is configured correctly but maybe someone can shed some light on this. Here is the config w/ip route:
User Access Verification
Password: Password: Password: Router>en Password: Router#cls Translating "cls"...domain server (68.87.64.196) (68.87.66.196)
Translating "cls"...domain server (68.87.64.196) (68.87.66.196) (68.87.64.196) (68.87.66.196)% Unknown command or computer name, or unable to f ind computer address Router#sh config %% Non-volatile configuration memory is being accessed, Try again later
Router#end Translating "end"...domain server (68.87.64.196) (68.87.66.196)
Translating "end"...domain server (68.87.64.196) (68.87.66.196) (68.87.64.196) (68.87.66.196)% Unknown command or computer name, or unable to f ind computer address Router#sh run Building configuration...
Current configuration : 1265 bytes ! version 12.2 service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname Router ! enable secret 5 $1$BrLc$K/A0I8PJb99nlHY6Vo2cp. enable password XXXXXXXXXXXXXX ! ip subnet-zero ip name-server 68.87.64.196 ip name-server 68.87.66.196 ip dhcp excluded-address 192.168.1.1 192.168.1.255 ! ! ! ! ! interface Ethernet0 description Comcast ISP ip address dhcp ip nat outside no ip mroute-cache media-type auto-select full-duplex ! interface Ethernet1 description Inside Network ip address 192.168.1.1 255.255.255.0 ip nat inside no ip mroute-cache media-type auto-select full-duplex ! interface Ethernet2 no ip address no ip mroute-cache shutdown media-type auto-select full-duplex ! interface Ethernet3 no ip address no ip mroute-cache shutdown media-type auto-select full-duplex ! interface Serial0 no ip address no ip mroute-cache shutdown ! interface Serial1 no ip address no ip mroute-cache shutdown ! ip default-gateway 66.177.184.1 ip nat inside source list 1 interface Ethernet0 overload ip classless ip route 0.0.0.0 0.0.0.0 66.177.184.1 no ip http server ! logging history debugging access-list 1 permit 192.168.1.0 0.0.0.255 ! line con 0 line aux 0 line vty 0 4 password XXXXXXXXXXXX login ! end
Router#sh ip route Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2 E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2 ia - IS-IS inter area, * - candidate default, U - per-user static route o - ODR, P - periodic downloaded static route
Gateway of last resort is 24.127.224.1 to network 0.0.0.0
24.0.0.0/24 is subnetted, 1 subnets C 24.127.224.0 is directly connected, Ethernet0 C 192.168.1.0/24 is directly connected, Ethernet1 S* 0.0.0.0/0 [254/0] via 24.127.224.1
Any and all help will be appreciated. Still learning the IOS
In article , r snipped-for-privacy@hotmail.com wrote: :I need a little help with this one. I have a 4500m that I use as a :broadband router. The issue I am having is that I can only get download :speeds of 500K but when I use the linksys router I can achieve 5 meg :download speeds.
You are forcing full-duplex on the link instead of autonegotiating it. The result is likely that the device at the other end is deciding it should use half-duplex, because that's the mandated default when an autonegotiating device does not receive duplex negotiation information. A clash between duplexes usually trashes the throughput badly.
