Load Balancing with two 2Mbit Frame Relay
Oct 15, 2006 4 Replies
Jump to replies (4)
Load Balancing with two 2Mbit Frame Relay open original image
I have Cisco 2610XM router with IOS 12.3 also I have two 2Mbit Frame Relay on Serial interfaces connected to same ISP. I wrote a configuration like below...
interface Serial0/0 no ip address encapsulation frame-relay ! interface Serial0/0:0.1 point-to-point ip address xxx.xxx.xx.xxx 255.255.255.252 encapsulation frame-relay no ip mroute-cache no shutdown frame-relay lmi-type ansi ! interface Serial0/1 no ip address encapsulation frame-relay ! interface Serial0/1:0.1 point-to-point ip address xxx.xxx.xx.yyy 255.255.255.252 encapsulation frame-relay no ip mroute-cache no shutdown frame-relay lmi-type ansi ! ip classless ip route 0.0.0.0 0.0.0.0 xxx.xxx.xx.xxx ip route 0.0.0.0 0.0.0.0 xxx.xxx.xx.yyy ip route xxx.xxx.xx.zzz 255.255.255.240
Does this config work for load balancing and fault-tolerance.?????
I want two 2Mbit Frame Relay work for load balancing and fault-tolerance.. Could somebody have sample configuration about this situation..
Thanks..
No,
Take f.ex the incident when one PVC is gone - You will still have senarios were the static route is installed and routing packets into a hole. I strongly sugguest you use some sort of routing protocol, like OSPF. As long as you have equal costs to the same destination, with multiple paths, you have L/B
HTH Martin
Not likley a providor will run OSPF with them. Use a simple solution such as multilink frame relay (MFR), talk to your providor about it, most will do it.
Could you please write me a simple configuration for multilink frame relay.
Thanks
Brian V wrote:
You cant click on the link and look?
