cisco timeout h225 fwsm command
Mar 20, 2006 1 Replies
I have a question about how this works: the "timeout" command.
Specifically for H225 messages. Is it listening for port 1720 after a TCP connection and then checking to see that a message is being sent or that thee is a reply? I mean when does the clock start and then stop?
What if a call stay's up for a long time and the TCP session stays up (persistently) does this mean the FWSM will just tear it down after a period of inactivity?
The documentation in the Command reference guide is not very good on this.
Hopefully someone here has played with this.
Thanks for any tips.
Ray
Increase h225 timeout , default is one hour.
set timeout value for h225 to 5 hours,
pix# timeout h225 5:0:0
Chuck erayara wrote:
